- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
for example if i draw a circle and then draw a line from the center of the circle outwards past the edge then autocad connects them together. i cant move them independently of each other. Any help would be appreciated.
[ The subject line of this post has been edited to include the product name by @handjonathan ]
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Thank you Pendean appreciate your time. The circle and the line are not connected but if you select just the line it moves the circle to. Just cant figure this one out.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
@hits4200 wrote:
yes, it is off. this is a weird one not doubt.
Here is your issue
You need to remove the Parametric Constraints you turned on https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-t...
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Thank you so much!!!!!!! constraintinfer value set was set to 1. Put it on 0 and solved the problem.
