ВeekeeCZ
en respuesta a: Anonymous
I tried both your drawings on AUTOCAD 2015 - it seems there is no problem. Copy/Paste or Insert... all is working fine.
But you should use PURGE sometimes... your drawings have 15+ Mb, after PURGE the size decrease to 1.2 Mb. If you keep your drawing clean you can avoid some problems like this. And you'll get much better response of the system.
