pendean
en respuesta a: riswanthespy
@ riswanthespy your file's content started from skewed/not to scale PDF. That's your problem. There is no consistent scaling factor between what is measured and what is listed.
heck, even your two 500M dimensions doo not measure the same due to the sloppy nature of their creation/not snapping to any points.
Garbage in=Garbage out as they say in the CAD world.
No fix. Sorry. You will need to find a more accurate document somewhere else. What you posted is a fudged document created by someone quickly and hastily for a site exhibit, not much else. It is very unreliable.
PLUS your DWG file is set to mm.
