01-11-2016
07:21 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
01-11-2016
07:21 AM
Inside AutoCAD.
The command is ‘DWGPROPS‘
You can add additional Meta information such as a Title, Subject, Author, Key words and comments. You can also add Custom properties such as the Drawing number, title and revision.
Outside AutoCAD.
Even with AutoCAD closed you can right click on a drawing file in Windows explorer to see the information you’ve added. This could help you find the file you are looking for when searching for data with Windows explorer.
Back Inside AutoCAD Again…
You can refer to these properties inside AutoCAD using Fields, in Text, Mtext or Block attributes.
