Gokul.h
en respuesta a: j.palmeL29YX
First of all, I'll extremely appreciate your effort for this clear video with each clear command's explanation.
Thank you so much J.Palme! You did a great work!
But So it is not possible to use "Region command" on this object?
I'll ask the user about this Loft Command method which you used then let you know soon.
If this method solves user issue, then I'll click "accept as solution" immediately.
Thanks again! I too learned the loft command method today from you because of that video.
Have a Sweet day!
