dbroad
en respuesta a: riswanthespy
  • There was no pdf attached to the file.
  • The file wasn't created with AutoCAD.
  • The actual dimensions weren't as noted.
  • The noted dimensions weren't between clearly defined points.
Please let us know:
  • What program was used to create the dwg file?
  • How are you determining distances?
  • Are you having trouble with x vs y scales or are there other scaling abberations?
  • Do you really need help with a pdf or with just fixing the posted file? If with a pdf attached to a drawing file, please post both.
Recommendations if this file is all you have:
  • Determine at least one distance between clearly defined points that you actually know. It should be the largest distance you can know for sure.
  • Then scale all objects in the model space about the 0,0,0 basepoint, using the reference option. Pick the distance, using object snap between 2 defined points.  Then enter the distance you know to be true.  Using actual dimensions should confirm that at least that distance is now correct after scaling.
  • Then repost this file and point out distances that aren't true.
Architect, Registered NC, VA, SC, & GA.
