Neil.oloughlin
en respuesta a: Neil.oloughlin
Thanks Kent however this doesn't seem to work for what I'm trying to do, it can still be exploded down to the smaller blocks. The end result needs to be a simple low poly model. Had some trouble with the command at first although seemed to work in wireframe view after exploding it down, otherwise I got an error about need to select at least two surfaces, but it could still be exploded back down to lots of small parts.
I can't attach the whole model as it's company IP but I took one part of it out and attached that, if it helps. I've also attached a low poly example of what I'm trying to get to.
Thanks.
