09-30-2022
01:03 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
09-30-2022
01:03 AM
@Kent1Cooper wrote:
@hmsilva wrote:
- Transform the 'Raster image' or 'PDF Underlay' in a 'Block Reference' (command 'block')
- Select the 'Block Reference' and correct X and Y scales in the Properties palette, by trial-and-error. (command 'properties').
- Explode 'Block Reference' (command 'explode')
Just be aware that the put-in-Block/Scale(s)/Explode approach can have unexpected results if a PDF underlay is rotated before being put into a Block definition. It seems not to be an issue with a raster image, but I didn't do extensive testing.
That's correct!
My suggestion it's just a workaround, since AutoCAD does not allow us to change differently Xscale and Yscale...
Trying to solve the 'unexpected results if a PDF underlay is rotated' perhaps import all objects as AutoCAD entities (command'_pdfimport'), then 'Block Reference' (command 'block') and then change X and Y scales...
Post a sample so we can all see what you're trying to achieve.
Hope this helps,
Henrique
