Kent1Cooper
en respuesta a: hmsilva
@hmsilva wrote:
  • Transform the 'Raster image' or 'PDF Underlay' in a 'Block Reference' (command 'block')
  • Select the 'Block Reference' and correct X and Y scales in the Properties palette, by trial-and-error. (command 'properties').
  • Explode 'Block Reference' (command 'explode')
Just be aware that the put-in-Block/Scale(s)/Explode approach can have unexpected results if a PDF underlay is rotated before being put into a Block definition.  It seems not to be an issue with a raster image, but I didn't do extensive testing.
Kent Cooper, AIA
