hmsilva
en respuesta a: riswanthespy
@riswanthespy wrote:
if i scale to a specific value one side of the diagram, it  is scaled as my inputs , while the other side is improperly scaled.
@riswanthespy
Do you means different X and Y scale?
If so, what i usually do is:
  • Transform the 'Raster image' or 'PDF Underlay' in a 'Block Reference' (command 'block')
  • Select the 'Block Reference' and correct X and Y scales in the Properties palette, by trial-and-error. (command 'properties').
  • Explode 'Block Reference' (command 'explode')
The result is a 'Raster image' or 'PDF Underlay' correctly scaled.
I had written a lisp to do this task, but I can't find it...
I'm currently under a heavy workload and I don't have free time to write it, maybe someone else can do it.
Hope this helps,
Henrique
