09-29-2022
01:27 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
09-29-2022
01:27 AM
Bonjour @riswanthespy
The imported PDF will behave as a block. It is possible to move it, rotate it and apply a scale factor.
You need a known reference according to your units used.
For example, on the PDF there is a 1 meter line.
Command: Scale
You select the PDF then, you select on the PDF the base point, then R, You show the starting point of the line then the end, and you answer 1.
The PDF is to the scale of the drawing.
Beware of snaps in the PDF, they are blurry and less accurate than AutoCAD.
Amicalement
