Alfred.NESWADBA
en respuesta a: BerndSchulze
Have you installed SP1 for AutoCAD 2016?
Have you had a previous release of AutoCAD installed and migrated the settings when you first started 2016?
I'm not sure about your "convert text to geometry" settings as (a bad) decission was done to modify that setting on 2 different places now (with AutoCAD 2016).
You showed in the video that you changed the setting in the plot-dialog ==> button "PDF-Options". Can you try additionally in the plot dialog to
  • select the "DWG to PDF.pc3
  • right from that selection click on "Properties"
  • in this new dialog ==> seelct "Custom Properties" and when that is selected you get a button in the lower half "Custom Properties" ==> click it
  • And now see if here the "Convert all text to geometry" is checked
If nothing helped: Can you upload the drawing + your "DWG to PDF.pc3"?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
