451 Vistas, 2 Respuestas
tags for dwgs and dxfs
I would like to start adding tags to my dwfs and dwgs so that they can be searchable through windows explorer? any idea how to do this? Thanks
pendean
en respuesta a: Anonymous
in AutoCAD, that's the DWGPROPS command.
For all other files, you can find many freeware to help if you find Window's own method cumbersome.
wispoxy
Inside AutoCAD.
The command is ‘DWGPROPS
DWG Props General TabDWG Props Custom TabDWG Props Summary Tab
You can add additional Meta information such as a Title, Subject, Author, Key words and comments. You can also add Custom properties such as the Drawing number, title and revision.
Outside AutoCAD.
DWG Props Windows Summary TabDWG Props Windows Custom Tab
Even with AutoCAD closed you can right click on a drawing file in Windows explorer to see the information you’ve added. This could help you find the file you are looking for when searching for data with Windows explorer.
Back Inside AutoCAD Again…
DWG Props inside AutoCAD
You can refer to these properties inside AutoCAD using Fields, in  Text, Mtext or Block attributes.
http://cadsetterout.com/resources/find-out-how-add-meta-information-your-autocad-dwg-files-propulate...
