ed57gmc
en respuesta a: dany_rochefort
In addition to what @dany_rochefort posted, the settings should be saved in a pc3 file. If you continue to use the System Printer driver, other programs can change the default settings. If you use a pc3 file, your AutoCAD settings will always be the same. To do this, use the Save As button shown in the dialog in the middle of Dany's image.
If you are already using a pc3 file, the printer's driver may have been updated, causing an issue.
Ed
How to post your code.
