- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
only print half a page with that portion / turned 90 degrees
What has happened? I come in today and try to print to a canon IPF760 and it wants to only print half a page with that portion of it turned 90 degrees. if i make a pdf file and send it to the plotter thru bluebeam it prints ok. haven't messed wiith anything to much due to being on a deadline, but i am getting really fed up with this version 2023. a new day a new problem.
***THE POST TITLE HAS BEEN EDITED FOR CLARITY***
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
It probably has nothing to do with the new version. You are probably using different plot settings. Share your PDF settings and your plotter settings.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
In addition to what @dany_rochefort posted, the settings should be saved in a pc3 file. If you continue to use the System Printer driver, other programs can change the default settings. If you use a pc3 file, your AutoCAD settings will always be the same. To do this, use the Save As button shown in the dialog in the middle of Dany's image.
If you are already using a pc3 file, the printer's driver may have been updated, causing an issue.
Ed
How to post your code.
