- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
AutoCAD - Fields Not Working
Hello Community:
I have been searching for days for a solution to my conundrum. Every time I use the field option on either the AutoCAD, AutoCAD Mechanics, AutoCAD Electrical the field doesn't work.
I lose the ability to use fields in general. and normally it would be if I change the field type, the original field is still working but when I change the type of field the attached happens.
The only way to circumvent this issue is to find an old drawing where the field works and passing it to the new place where I need it and it's very frustrating.
I am baffled to no end on how to fix this issue, I already reinstalled all the AutoDESK products from scratch, the only option I have left if I don't find a solution is to wipe my whole system clean and re-install the Operating System as a new computer.
Thank you very much for you time.
[The subject line of this post has been edited for better findability by @handjonathan Original: Fields Not Working ]
JB.
