gianluca.rizziBEA9N
453 Vistas, 5 Respuestas
Exporting blank JPG with JPGOUT
Good afternoon,
my issue is that when I try to export a selection 3D drawing as a JPG (with the command JPGOUT) I just obtain a blank file.
The same happen when I try to export the selection as a BMP.
Best,
Gianluca
Curious, are you successful in generating the JPG if you use the PLOT command, select PublishToWeb JPG.pc3 and window the area to create the JPG?
Paul Li
IT Specialist
@The Office
Unfortunately I do not have such option in the plot window.
I can just plot as a PDF.
I am working on a mac computer, I am not sure if it matters.
you should post to here: AutoCAD for Mac Forum - Autodesk Community
Paul Li
IT Specialist
@The Office
Thank you very much for the help!
sure, hopefully someone can provide you with better assistance there....cheers!!!
Paul Li
IT Specialist
@The Office
