paullimapa
en respuesta a: AolahSDA
To add to what @TheCADnoob pointed out, assuming those slides are inside a slide library file, you should look for the file extension .SLB.  Make sure this file is placed in AutoCAD's support file search path.  Also make sure the folder names in that search path does not contain any parentesis "(" or ")" in the name because that will also throw off the locating of the slides inside the slide library.
Paul Li
IT Specialist
@The Office
