pendean
en respuesta a: WBROWNMG7FU
@WBROWNMG7FU wrote:
P.S. I tried uploading PDF examples, but was prompted that the file type (PDF) was invalid.
Sure they are PDFs? I seem to be able to add them here, no issues.
@WBROWNMG7FU wrote:
I regularly use PUBLISH to convert multiple pages to PDF. I am printing in Monochrome. When I use PUBLISH, every line that is not horizontal or vertical comes out light gray and hard to see, which is my issue. When I use PLOT, to plot a single page, all of the lines come out black and uniform, as expected....
The gray washed-out line issue only occurs when using PUBLISH. Anyone have a solution?
I don't see screenshots of your PLOT and PUBLISH commands pop-up here "ready to do", can you do so now?
And a screenshot of your ABOUT command pop-up too please.
Your PDF Viewer is...?
And if you try a different PDF Viewer, does the problem go away?
