08-23-2022
10:42 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
08-23-2022
10:42 AM
AutoCAD 2023 - Point Filters Pauses/Hangs AutoCAD on Move command
When using Point filters with the move command the program will Pause/Hang. These steps worked perfectly for the last 10 or so versions of AutoCAD. I tried both command line and using the "Shift-Right Click menu" and they both hang.
- Move
- Select a Object
- Select a Base Point
Now I want to filter out coordinates for my destination.
- Type .XY
- Type NONE
- Type @
Now the program hangs on (need Z)
If I hold shift with will resume but the command history states
>>Enter new value for OORTHOMODE <0>:
Then the commands will continue as normal and work.
