08-22-2022
12:22 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
08-22-2022
12:22 PM
@javiperques wrote:
The extension "Hatch Maker" (to create new patterns) loads correctly but when I write the "DRAWHATCH" command, the 1x1 box that is supposed to appear doesn't appear.
I haven't used that, but looked at the one @pendean linked to. Your problem would occur if the current Layer is turned off, which doesn't seem likely, but make sure it's on. [Or if the current Layer or the current entity color is set to the same color as the background....]
Does it get as far as Zooming in around the square from 0,0 to 1,1, whether you see the square or not?
Is your current Polyline width [PLINEWID System Variable] set to something large, not to 0?
Kent Cooper, AIA
