Hello @erika.kosikova94KUL
Option 1.
An EASY way would be to make the attribute invisible using BATTMAN command. Making it invisible doesn't delete the attribute it just makes the attribute itself 'hidden.'
Option 2.
Another way is using the Block Editor. Select block=>right-click=>select Block Editor from shortcut menu. Then in the block editor select the attribute and delete it. Next, close the editor making sure to save the change when exiting. Doing it this way changes the  block definition in this specific drawing.
Option3.
Insert the block with the attribute in as many places as you wish. Select all 'instances' of the block=>Go to Properties Palette=>Highlight and delete all the attribute values all at once.
(NOTE: If the attribute values vary from block-to-block, then *VARIES* will be displayed for the value.)
Chicagolooper
