- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Replace block with attributes with block without attributes
Hi all,
I would like to ask if there is any easy way how to replace (with command BLOCKREPLACE) an old block which contains attributes with a new block which does not contain attributes? The problem is that attributes from old block are always visible after replacement and command ATTSYNC is not working because the new block does not have any attribute.
Thanks a lot!
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Would you please share with us the two blocks .. for testing ?
Imad Habash
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Unfortunately, I cannot share the blocks I used because it is confidential (i had this problem with title blocks) but i prepared two blocks - One with attribute and one without attribute and I have the same result. See attached.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hello @erika.kosikova94KUL
Option 1.
An EASY way would be to make the attribute invisible using BATTMAN command. Making it invisible doesn't delete the attribute it just makes the attribute itself 'hidden.'
Option 2.
Another way is using the Block Editor. Select block=>right-click=>select Block Editor from shortcut menu. Then in the block editor select the attribute and delete it. Next, close the editor making sure to save the change when exiting. Doing it this way changes the block definition in this specific drawing.
Option3.
Insert the block with the attribute in as many places as you wish. Select all 'instances' of the block=>Go to Properties Palette=>Highlight and delete all the attribute values all at once.
(NOTE: If the attribute values vary from block-to-block, then *VARIES* will be displayed for the value.)
Chicagolooper
