paullimapa
en respuesta a: shahdswehli
Having foreign language characters could definitely be the issue. Since you have the original pdf, have you tried opening that with a pdf program to see if you can successfully get proper output?  Perhaps flatten pdf so characters are also embedded? While in AutoCAD what print device have you tried?  Did you try DWG to PDF to see if you can get another pdf with proper characters? Lastly post sample of pdf so we can all try.
Paul Li
IT Specialist
@The Office
