08-04-2022
08:45 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
08-04-2022
08:45 AM
Are they in straight rows? If so, make not an Array of independent objects, but an Array object, that is, an ASsociative Array [an option in the process of the Array command, after you've specified Rectangular]. Then you can change row and/or column spacings (and the number of rows and/or columns) either by grip-editing or by typing values into the Properties Palette:
Dragging the blue triangular pointer-grips nearer the lower-left square insertion point changes the spacings. The ones at upper left and lower right change the number of columns/rows without affecting the spacings. The square grip at upper right [not always visible in my video] can change the numbers of both columns and rows together.
Kent Cooper, AIA
