kasperwuyts
en respuesta a: llaframbo
Usually, your line weights aren't set in the drawing file, but are determined by a plot style table, which you select at the top right corner in your expanded plot window. (for example, 'monochrome.ctb', 'grayscale.ctb')
What this file does is map each of the 256 standard colors to a thickness.
So my guess is the drawing was made using a different plot style than when you tried to plot it. Ask the person who sent you the drawing to send his plot style table along. Or if that is too technical, make him publish and etransmit the drawing to you. That way, the plot style table gets sent along automatically.
Best regards
Kasper Wuyts
_______________________________________________________________________________
If this post solves your problem, clicking the 'accept as solution' button would be greatly appreciated.
