TheCADnoob
en respuesta a: psw1125
If I understand your question and data extraction isn't what you are looking for, There are ways to get that information, but you will have to build (or adapt) things to get it done.
If you take your roll line and move the beginning to the origin then use a block that calls out xy coordinates you can use the path array to insert your blocks at a set distance on your line. (you will have to explode the array and REGEN after). (block i used found here)
Then for the slope you can use a block similar to this to get your slopes. (this block doesn't give you the value you need but demonstrates that it can likely be done) (you can probably take the cot of the angle to get your slope)
I would spend the time to develop the tools you need so they can meet all the challenges of more complicated roller systems. Check out blocks and dynamic blocks and fields in blocks.
CADnoob
