- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
AutoCAD unable to open because of .bak files -- Drawing Recovery?
Our network drive where we store all autocad DWGs and .bak files is down. I cannot open a new/blank DWG because I believe autoCAD is trying to locate the .bak files on our down network drive because of the DRAWING RECOVERY command that happens when autocad crashes. Is there a way to disable this outside of autoCAD?
O
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Not sure if the cause of your problem is because of drawing recovery files but try the following:
1. With all programs closed, open Windows Explorer and enter %temp% and select all and delete
2. Open regedit and see if there are entries here then delete:
...HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\Rxx.x\ACAD-xxxx:xxx\Profiles\**your profile name**\Drawing Recovery...
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi
Autocad dose not finding the .DWT file(that is the reason that you can not open a new blanc file, probably its set to open a .dwt file from your network), check if you find in your pc, see image above, .dwt file, then see image below
ant the last, find autocad.dwt file ,next open.
