rkmcswain
en respuesta a: SRodgers723
To answer your question directly, you can use one of the relatively new features of AutoCAD in the Purge dialog - the "Find Non-Purgable Items".
Keep in mind the nested nature of table objects in AutoCAD. For example, I selected the first textstyle, and it tells you that it is being used in 3 linetype definitions.
Then I went to the linetype definition containing the string "CITY_WATER", and there is the "stuck reference" - objects in a block definition. So why aren't the blocks showing up anywhere? They are all (2782 of them) anonymous blocks, which also explains the 2MB file size for what appears to be an empty drawing.
