nextvkin
en respuesta a: Anonymous
Came across this very old thread, but just in case someone else wants to know, it can be done. You need to delete the existing field for the revision numbers and create a new one using custom sheet properties, and give it a default value of whatever you want the revision for the sheets to be. This way all the sheets will have the same revision code, and you can still change the revision code individually later if you want to because it's a custom sheet property not custom sheetset
property.
