evansTSMR
798 Vistas, 7 Respuestas
Cannot modify Etransmit setup
Using AutoCAD 2015 - when I run Etransmit the default is to create a zip file, but I want to use the "Folder (set of files)" option instead, so I can Etransmit several drawings in succession and then zip them all together into one zip file, plus tweak a few other settings (like "include fonts," etc., all of which are unchecked in the default setup).
However, when I click OK after making these selections on the Modify... page, AutoCAD presents me with an error message: "Unable to save transmittal setup to registry." An hour ago it worked. Now it is not working. Neither restarting AutoCAD nor restarting Windows (Windows 7) has resolved the issue.
Please advise.
Michael Evans
