leeminardi
en respuesta a: david.penney00
I do not believe that you can create a parallel projection for a camera view.
I think using dview may be better for your application.
Create a ucs with the xy plane at the desired 4.5° angle.
Invoke the dview command and select the geometry you want to analyze then [Enter]. Give the cl (clip) option then F (front) and adjust the slider that controls clipping as desired. Give the CL option again and then B (back) and adjust the slider again. you can zoom, use dist etc. in this view.
lee.minardi
