dmfrazier
en respuesta a: scoutctmarine
Another option is to select one of the "ARCH full bleed D..." page sizes (assuming they're available with the PDF output driver you use), which has zero margins:
If it's not available, you can either modify an existing page size or create a custom page size. (There may be pitfalls to doing this; if so, I'm sure others will point them out.)
