Dsavvy
462 Vistas, 5 Respuestas
CAD 3D Corner Piece
Anyone know how I can make this 3D piece with a 90° corner return? Basically a molding wrapped around a corner
Kent1Cooper
en respuesta a: Dsavvy
SLICE a 45° wedge off the end.  MIRROR in an appropriately defined UCS.  UNION if you want.
Kent Cooper, AIA
Dsavvy
en respuesta a: Kent1Cooper
No idea how to slice a 45° angle :cara_sonriente_con_la_boca_abierta_y_los_ojos_cerrados:. Can you show me please? I attached it
Patchy
Make 2 pieces and put together at 90 degrees, draw 2 lines at 45 degrees and use them as cutting plane to slice.
Pick end points of one line and 1 end point of the other line.
j.palmeL29YX
>>Click<<
or
>>Click<<
Jürgen Palme
Kent1Cooper
It can be done easily enough without actually drawing Lines for the purpose.  Either by setting a UCS or by 3D Rotating in the WCS, get to the point where the Z axis aims upward from the top:
In PLAN view so that you're looking down from above:
SLICE
{select the 3D Solid, Enter to complete selection}
{pick some point A}
@Anonymous,10 {to get point B -- does not need to be beyond the other side, but anywhere in 45° relation to A}
@0,0,1 {third point for Slicing plane}
{pick to the right to keep that part}
MIRROR
{you know what to do}
Kent Cooper, AIA
