debbiebasta
643 Vistas, 14 Respuestas
Lines are showing perfectly in model space but missing in layout space
My lines are all showing perfectly in model space, but a percentage of lines are missing/ not appearing in layout space.  I have a presentation on Monday and need this repaired quickly.
Note:  I sent a several messages on Thursday regarding an overrun of stack-based buffer in the application, which was followed by a message stating that the breakpoint had been reached (0x80000003) at location 0x00007FF840EB3D7D.  Images of these messages were sent.  I have not received a resolution for this yet. I am assuming all issues are related.
My computer is running Windows 10 Pro, version 21H1.
Thank you
debbiebasta
en respuesta a: debbiebasta
Also, In addition to message just sent....when in layout space and all hatch is turned on, when I run my cursor across areas that show hatch, all of the drawing below disappears until I stop moving the cursor.
Thank you,
Patchy
debbiebasta
en respuesta a: Patchy
Yes, this has nothing to do with a frozen layer in a viewport. There is
something glitchy going on here. See if you can locate my earler posts
from thursday referencing error messages about buffer and breakpoint being
reached.
For giggles I just turned off the hatch in layout space (was going to make
sure some of the lines didn't get put on the wrong layer). When I turned
off the hatch in the layout space.....all the lines appeared. Turned the
hatch back on.... and now all lines are there. (???) I have an
application glitch of some sort that needs a repair. Please advise.
your reply above this line -##
Virus-free.
www.avg.com
<#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
RobDraw
Are you having the same issue in other files?
Rob
debbiebasta
en respuesta a: RobDraw
Hi Rob,
This is the only file I am working in. No changes. All was working
perfectly up until Thursday, which was when I sent in the original messages
referencing errors, buffer/ breakpoint being reached etc. with attachments
of screenshots (3). If you can locate those messages it would be helpful.
RobDraw
Me looking for your messages is nit helpful. You should find and reference them yourself, they may not even be helpful as I think the problem is in your file.
Please share it for inspection.
Rob
debbiebasta
Attaching file.
Pointdump
Hi @debbiebasta,
I don't see any file attached. Please try again.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
debbiebasta
en respuesta a: Pointdump
ok, thanks
debbiebasta
Attached.
Pointdump
Hi @debbiebasta,
Thanks for posting your drawing.
I've been looking it over. It's fairly involved. But no lines are jumping out as missing. A screen shot or two would be helpful showing which lines are missing in which layout.
Dave
Dave Stoll
Las Vegas, Nevada
debbiebasta
My earlier messages will clarify. The lines were not showing up in
layout. I turned off the hatch to verify the lines were all on the correct
layer, which they were. when I turned the hatch back on, the lines were
visible. Glitchy things going on with the program.
Pointdump
"My earlier messages will clarify."
Sorry, that would be not.
"The lines were not showing up in layout."
WHICH lines? A screen shot would help to see what you see.
"Glitchy things going on with the program."
I wouldn't be too quick to blame the program. I don't see any problems with your drawing. Might be a graphics card problem.
Dave
Dave Stoll
Las Vegas, Nevada
pendean
@debbiebasta wrote:
Attached.
Your active layer is turned off in most of your (inexplicably) unlocked preset viewports
HTH
