j.palmeL29YX
en respuesta a: austinkb
@austinkb wrote:
Let me try asking a different way.
Please ignore my ignorance, but your request is still not clear to me.
Do you want to increase the distance between the posts and fill the space  with additional geometry or do you want to change the geometry between the posts to fill the space between or ... ?
And also you did not yet answer the question which program you're using. The example above was obviously not created with plain AutoCAD. And in the case the geometry (their dimensions) should be changed it makes a difference if you have 3DSolids or Surfaces or (as in your example after exploding the AEC-object twice) 3DFaces or whatever.
Please post a (manually draws) example how looks your initial geometry and how should it look after "stretching".
Jürgen Palme
