Hi @matthew.ross.hdrinc,
That does sound frustrating.  This may be a corrupt or missing coordinate system file.  Please try the following:
  • Check the folder C:/Users/UserName/AppData/Local/Autodesk/User Geospatial Coordinate Systems for any custom .CSD files such as Category.csd. These can become corrupt, and cause the list to display incorrectly. Erasing these .CSD files remove the errors, and allow all Coordinate Systems to be listed.
  • Replace the Coordsys.CSD file by cutting and pasting the Geospatial Coordinate Systems folder from any working machine or install into the following location on your machine: C:/ProgramData/Autodesk/Geospacial Coordinate System XX.XX. For example, these are the folders installed on my system.
All the best,
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
