s222290629
207 Vistas, 2 Respuestas
How to match properties of a line to a block
Hi ,
I need to know how can I match a line properties with a block.
Kind regards,
Arman
imadHabash
en respuesta a: s222290629
You can not match a line properties with a block !!
Imad Habash
Kent1Cooper
If I understand correctly, you would need to edit the Block definition so that all objects in it are assigned ByBlock color and linetype [and other properties if you like -- lineweight, transparency].
Kent Cooper, AIA
