Dennis.Meehan
298 Vistas, 2 Respuestas
Easy way to check all dimensions are associative?
Associative dimensions on drawings become dissociated. Is there a routine that can check all of the dimensions in a group of drawings and flag dimensions that are not associative?
Can I make a dimension that becomes dissociated change color to flag it?
cadffm
en respuesta a: Dennis.Meehan
ВeekeeCZ
Try this. It selects both, not and partially associated dims.
(defun c:SelDimUnAssociated ( / isDimAssoc? m s i e)
  ; by Vl. Michl CADStudio
  ; returns nil or assoc point number
  (defun isDimAssoc? (diment / elst dict)
    (and (setq elst (entget diment))
	 (setq dict (cdr (assoc 360 elst)))
	 (setq elst (entget dict))
	 (setq elst (entget (cdr (assoc 360 elst)))))
    (cdr (assoc 90 elst)))
  (princ "\nSelect dims to analyze associativity ... ")
  (setq m (ssget "_I" '((0 . "DIMENSION"))))
  (if (setq s (ssget '((0 . "DIMENSION"))))
    (repeat (setq i (sslength s))
      (setq e (ssname s (setq i (1- i))))
      (if (= (isDimAssoc? e)
	     (cadr (assoc (cdr (assoc 100 (reverse (entget e))))
			  '(("AcDbAlignedDimension" 3)
			    ("AcDbRotatedDimension" 3)
			    ("AcDbRadialDimension" 2)
			    ("AcDbDiametricDimension" 2)
			    ("AcDb3PointAngularDimension" 7)
			    ("AcDb2LineAngularDimension" 15)
			    ("AcDbOrdinateDimension" 2)
			    ("AcDbRadialDimensionLarge" 2)
			    ("AcDbArcDimension" 7)
	(ssdel e s))))
  (if m (sssetfirst nil nil))
  (if (and s (not (zerop (sslength s))))
    (sssetfirst nil s))
  (princ)
