stephanYN6LU
en respuesta a: ebsoares
It is still a pain in the but to find/replace Mtext in autocad even with the "\U+000A" function (which it does work), especially when you have to edit a lot of drawings through a lisp routine. The problem I face then, although the text have been replaced, it makes it a weird format, until you go into that mtext edit and exit afterwards without editing, and then the layout will readjust to the correct format.
Above is an example before going into the editor, and below is what happens if I do what I have described
Please take note I haven't made any changes except going into the editor and exiting. It is a bit annoying to fix the layout, I hope the devs can make our lives a lot easier with a patch to fix this issue.
