- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I've noticed this as well. In previous versions, 2022 for example, when a layout tab is copied, the copy would be placed after the highlighted location (vs "move to end") within the "Move or Copy" dialog. In 2023, it is impossible to copy the selected tab to the next slot.
For example creating a copy of tab Layout2 to between tabs Layout2 & Layout3 is not possible. If Layout2 is selected, the copied tab will be placed before Layout2. If Layout3 is selected, the copied tab will be placed after Layout3.
This is a bit challenging to describe in words, but ultimately the protocol is as follows: when a copy of a layout tab is made, the copy either moves before the target location if the target location is the copied tab or any tab before it. Or if the target location is after the copied tab the copy will be placed after the target location.
Again, if sequencing is important the copy can only be placed just before the copied tab and so will require two additional steps, either renaming of both tabs or moving and renaming the copied tab.
