jpCADconsulting
en respuesta a: ChicagoLooper
Hi folks,
Here is some more info that may help... I hope.
I took a good long look at the two machines, the one that opens the file properly (the map and line work align) and the one that opens the file improperly (the map and line work are misaligned).
On the machine that 'works' "Civil3D 2019 Object Enabler" was installed
On the machine that does not 'work' it was "Civil3D 2019.3 Object Enabler"
As this was the only difference I could see I uninstalled "Civil3D 2019.3 Object Enabler" and installed the older version.  No luck. Misaligned.
I then uninstalled the Civil3D 2019 Object Enabler altogether. Bingo. the Map and Line work aligned!!!
I repeated this a few times to test.  Any version of C3D OE installed - misaligned, uninstalled, looks great.
As we are testing AutoCAD 2023 for deployment, I decided to test that as well.  Same thing.  Civil3D 2023 Object Enabler installed - misaligned, uninstall C3D 2023 Object Enabler... looks great!
Any ideas?
