aruckerY7D6L
en respuesta a: Washingtonn
I was afraid of that. I wish I could simplify these parts quickly but does sound like it would be a long process to basically re-model all of the connections. Was hoping that filling in the solid would lead to those interior lines being removed or a way to make a separate skin of only the outside. I was able to clean it up some with the SOLIDEDIT and clean but still leaves a lot of lines. For now, we have decided to make a separate file with only the equipment in so we can keep the main file size down and just XREF in to the main as needed.
Your method for the right hand version would indeed be the way to go though if I had the time to do it; Ill need to do that in the future when work is slow and I have time to. Thanks!
