01-04-2016
02:49 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
01-04-2016
02:49 AM
if you select all objects you'll see symbols like that:
That means you have defined a lot of constraints and these constraints can sometimes make a system slow, and the more exist, the more chance the recalculation slows your system down to inaccessibility.
As the used constraints are in most cases of type "perpendicular" I guess you didn't meant to use them during construction, more like "it just happend" ![]()
To solve that
- first turn off the automatic creation of the constraints using sysvar CONSTRAINTINFER (>>>details<<<)
- in the current drawing delete all the constraints created using command _DELCONSTRAINT ==> _ALL
HTH, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Alfred NESWADBA
