- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
@ovenegas6BFTN wrote:
.... The spline now can be hidden line and show the hidden dashed line graphics. But I am afraid that at some point in the future it might begin to curve, etc, .... So let me ask, how to convert it now to a continuous line or continuous pline that will keep showing the dashed lines?
Yes, the Spline version will get curvy if you Stretch or grip-edit to change the shape of it.
Is the 3DPolyline planar? That is, does it lie in a flat plane, even if that is not the XY plane of the WCS or the current UCS? If it's not planar, Exploding it into Lines or using the trick to make it into a Spline are your only options, because other-than-3D Polylines [whether "heavy" or "lightweight"] can only be planar.
See my earlier reply about what you can do if it is planar but not in the current XY plane. I also find, if it's planar, and seemingly only in or parallel to the WCS XY plane, if I draw a Line attached to one end, and JOIN the 3DPolyline and the Line, the result is a regular LWPolyline, from which the added line segment is easily removed.
