jpCADconsulting
584 Vistas, 8 Respuestas
GEOMAP image shifted on all but one computer
Hi folks,
I'll try to get permission to post data if I can but for now, here is the issue:
My clients had a project that hit a milestone a few months ago. It's been sitting since then but now they are beginning to open the files and work on it again.
The base file has a geo marker and a map that for some reason is now shifted about 3000' to the left when the file is opened on any computer except one, on which the file looks correct (the linework and the map align).
Same version of AutoCAD (2019 - although I'm testing 2023 for an install and I get the same issue).
Is there some setting or system variable that could be different on one computer that is causing it to display properly on that machine?
Thanks as always for any insight.
-JP
