Kent1Cooper
en respuesta a: ovenegas6BFTN
It's not a version-specific bug; 3DPolylines have never "honored" non-continuous linetypes.  EXPLODE it.  You can leave it as the resulting independent Lines, or if the original was planar and in the XY plane, JOIN them together into a lightweight Polyline.  [If it was not planar, or not in the XY plane, they'll just Join into a 3DPolyline again, so you'll want to leave them as Lines, OR if the original was planar but not in the XY plane, you can set a UCS to the plane of the Lines, and use PEDIT's Join option [not the JOIN command] to make them into a lightweight Polyline.]
Kent Cooper, AIA
