- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
@Anonymous wrote:Hi,
I'm desperate.
I started working with Autocad only couple of months ago with version 2015. Creating a new .dwg file works just fine but after edited file exceeds a certain amount of lines/details/younameit Autocad turns really slow and when I continue editing it finally stops responding completely. Then there's nothing I can do anymore. I have re-created same drawings from point zero and done several tricks I've found on these pages but none of them has helped.
I have a new computer with enough processor and memory capacity so it shouldn't be the issue. Also the files are pretty small (only nx100 kt). I attached one of the problematic files.
Thanks in advance,
BR, Henna
When a file starts behaving oddly I always AUDIT then save and close the file then RECOVER the file and see if that helps.
