qnhat1771
277 Vistas, 3 Respuestas
Enable Hardware Acceleration and pickbox is delay
Now I use Autocad 2022. When I enable Hardware Acceleration in Graphic Acceleration, pickbox is delay. How I fix it? Thank you!
imadHabash
en respuesta a: qnhat1771
I suggest to check if any updates needed to your AutoCAD ?
Imad Habash
qnhat1771
@imadHabash I already update but it's not working. Thanks
pendean
Set GFXDX12 variable to 0 (that's a zero) then restart AutoCAD/LT2022: reverting to DirectX11 fixes similar problems for most users.
Also consider turning off LINESMOOTHING and LINEFADING variables: if still no relief then start GRAPHICSCONFIG command and change the 2D Display Settings pulldown from "advanced mode" to one of the other choices.
If all else fails, then turn off Hardware Acceleration as a last resort, and start a support ticket through your subscription portal as explained here https://knowledge.autodesk.com/customer-service/account-management/users-software/support-options#:~....
