dbroad
en respuesta a: sunyaer
You said that you'd tried adding a rotation parameter before.  You do realize that every parameter has to also have a related action to actually do something, right?  Use the parameter sets tab of the authoring palette instead of the parameters tab to automatically get the related action.  Then you must select the objects that the action affects.  Right click on the action.
Architect, Registered NC, VA, SC, & GA.
